Big cam 346 power?
Old Apr 1, 2008 | 10:23 AM
  #41
92ZZ3RS's Avatar
it sounds bad *** Prin!!!!!!!!!!!!great looking and sounding car. i'm ready to see how it pulls now. we need to try them out soon.
Old Apr 1, 2008 | 03:12 PM
  #42
Prin's Avatar
Only if you use your street tires man!
Old Apr 1, 2008 | 09:44 PM
  #43
justanls1's Avatar
Good #'s. Now go get that beast to the track.
Old Apr 5, 2008 | 10:47 PM
  #44
chevynation's Avatar
Man that thing is begging for a Fast 92. That's the most power I've seen from an LS6 though.
Old Aug 21, 2008 | 12:24 PM
  #45
99Ls1fever's Avatar
What octane are you running with 12.2 compression???
Old Aug 21, 2008 | 12:26 PM
  #46
99Ls1fever's Avatar
Originally Posted by WizeAss
440......
MellowYellow has a RPM6.... 244/248 in a 346 with 10bolt and makes 440ish..... optimal setup with waterpump, pulley, and good exhaust thru a T56 might make 470ish.
How much was the John Beck intake???
Old Aug 21, 2008 | 12:29 PM
  #47
99Ls1fever's Avatar
Originally Posted by Demonicbird00
im on a 245/250 cam when i dynoed 456 i still had the stock wp, now i have a remote ewp and a belt that runs from the crank to the alt
-brandon
what is the belt number for the alt to crank???
Old Aug 21, 2008 | 03:14 PM
  #48
GrannySShifting's Avatar
Originally Posted by Prin
The verdict is in! It made 457 / 414. This is through a ls6 intake. Hopefully in the next few months I ca get a FAST 92/92.
I am still stoked!
I was close
Old Aug 30, 2008 | 07:08 PM
  #49
Prin's Avatar
it is tuned for 93
Old Aug 30, 2008 | 07:37 PM
  #50
Jim'sZ28's Avatar
nice results.My cam is close to that,debating which heads
Old Sep 4, 2008 | 08:18 AM
  #51
AINT SKEERED's Avatar
i have high hopes for my 11.73 to 1 347. My cam is a futral 239/243 .612 lift 112 lsa 110 cl . My heads are 5.3 heads that have been milled to 54 cc chambers with 2.0 1.60 valves and flow 283 @550 lift. My down fall wll be starting with a 6.0 truck intake untill I get a vic jr setup for it. THis will be in a 2300 lb 64 Nova tube chassis , fiberglass front 1 pc clip, lexxan glass and glass rear trunk lid. th 350 with 8 " BTE converter . 4.30 gears with 31x13x15 MT drags slicks.
I am going to see if the truck intake will take me to my goal of a 10.0- 10.20 bracket car before buying a better intake.
You have had great results.
Old Sep 4, 2008 | 08:56 AM
  #52
PewterScreaminMach's Avatar
I know this is an older thread but those are some good results. Did you ever end up throwing the 92/92 setup on there? I'd love to see how it does with that and how it does at the track.
Old Sep 6, 2008 | 05:57 PM
  #53
LSGunZ28's Avatar
with 1 7/8 headers, a FAST 90/90 and make sure you PTV clearance is okay with that cam ( you will need valve reliefs or to flycut the pistons) but that should make 470+rwhp
Old Sep 6, 2008 | 09:50 PM
  #54
Prin's Avatar
I have had some other issues with the car, so no, I havent got the fast 90/90. I have had an oil leak that I could not detect. But, I finally found it. It was the oil pan gasket. Therefore, the K member was dropped and we now have it fixed. I sould get the car back tomorrow. I am so excited! Now I can save my money in teh car fund and get he fast intake.
I would like the bigger headers, but the headers already hit the steering rod. I dont think the bigger headers would fit.
It is a trong motor, but most of the power is up top. I dont like beating on my cars and therefore, I am scared to get it up there. But, I let my borther have it for a week and he whooped up on some blown Cobras. People in my hometown could not believe how the car performs.
Old Sep 7, 2008 | 09:35 PM
  #55
CraZee ZO6's Avatar
nice #S with the 5.3 head!
heads/cam 346 are lovely
Old Sep 7, 2008 | 10:21 PM
  #56
sounds like a great set up but if youdont like bringing the rpms up high, you may have the wrong combo for you.
either way, nice setup.
Old Sep 12, 2008 | 06:39 PM
  #57
Demonicbird00's Avatar
dont be scared of it there. thats where the power is. itll stay together when running upto 7k just dont drive like that everyday lol. ill beat the ***** off my car at the track and then ***** foot it around on the street. i now have 125k on the motor and stock rod bolts
-brandon
Old Sep 12, 2008 | 08:19 PM
  #58
Ironxcross's Avatar
very nice except for the raspy exhaust.
Old Sep 13, 2008 | 09:44 PM
  #59
Prin's Avatar
That was through an opened cutout...
Old Sep 13, 2008 | 11:11 PM
  #60
Caspernicus's Avatar
Wind that bitch to 7k prin! lol
