TSP H/C dyno sheet and video
Old Feb 20, 2008 | 07:51 PM
jcolews6's Avatar
Default TSP H/C dyno sheet and video
Stock intake, TB and cats,
Old Feb 20, 2008 | 07:54 PM
jcolews6's Avatar
Default Video
http://s231.photobucket.com/albums/e...t=MOV00633.flv
Old Feb 20, 2008 | 08:08 PM
BuBbABFP's Avatar
Very nice numbers mang!! I am going with the same cam just different heads I cant wait.
Old Feb 20, 2008 | 11:37 PM
jcolews6's Avatar
Thanks, you will enjoy it. It is a huge rush driving this thing, good luck
Old Feb 21, 2008 | 12:31 AM
BayAreaSS's Avatar
Thats pretty good considering you don't even have all the bolt ons and cats
Old Feb 21, 2008 | 07:55 AM
venom ws7's Avatar
Great numbers man Congrats and through Cats and stock TB.
Those TSP PRC heads are awesome.
Is it me or the car is a littel lean??
Old Feb 21, 2008 | 09:00 AM
99zman's Avatar
nice hp but why is the tq so low all the time with the tsp heads.
Old Feb 21, 2008 | 09:06 AM
massls1guy's Avatar
good point
Old Feb 21, 2008 | 09:57 PM
BuBbABFP's Avatar
Looks very lean...
Old Feb 21, 2008 | 09:59 PM
'Trust''s Avatar
That looks very lean, cutout with the A/F in the tailpipe? That needs to be richened up, you'll lose some power, but at least not a piston. Good numbers though, the TQ is a little low, but not bad!
Old Feb 21, 2008 | 10:07 PM
jcolews6's Avatar
The F/A ratio does concern me. The tuner did mention bigger injectors as they were running100 % duty. So should I call and complain about this? Thanks
Old Feb 21, 2008 | 10:56 PM
massls1guy's Avatar
That AFR doesn't look right, so flat. If you ran out of injector it would ramp up (lean) as the revs climb. My dyno graph looks lean at the start, then goes more rich as the revs rise.
Old Feb 22, 2008 | 08:50 AM
PewterScreaminMach's Avatar
Sounds like you need some injectors. The numbers look pretty good, but you don't want to risk hurting something.
Old Feb 22, 2008 | 09:15 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If the AFR is accurate, you could actually pick up some power by giving it more fuel!
Nice results for the mods you've got though!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 22, 2008 | 03:04 PM
jcolews6's Avatar
I talked to the tuner today and he said it was at the tailpipe and the cats confuse the wideband. The is A/F is 13.1 to 13.5. Ill be taking it back in two weeks with some upgrades and will repost. Thanks guys
Old Feb 22, 2008 | 05:41 PM
venom ws7's Avatar
Are you running stock fuel pump too???
With bigger injectors and pump I think the tuner can add more timing so you have some HP and TQ left on the table.
Old Feb 23, 2008 | 10:37 AM
jcolews6's Avatar
Ractronic w/ hotwire.
