Got Torque? Rapid H/C package results...
Old Mar 12, 2008 | 02:08 PM
Johny GTO's Avatar
Now i would love you to swap heads. Try out some AFR's, and some LS6 stage 3's from varying companies (TSP, Patriot, livermoise, etc).
Dont change anythin but the heads. it would be a nice comparison for the different heads to see what we get.
Old Mar 12, 2008 | 03:25 PM
52172's Avatar
there was a gm high tech that did that on an ls2 shortblock I believe. TF made the best numbers and afr wasn't very far behind just about 7 or 8 rwhp. Dart was the worst. Livernois was up there with a factory casting too.
Old Mar 12, 2008 | 10:31 PM
98blueSScamaro's Avatar
Default bumped up the CR
Originally Posted by mikey
Yes, you are right. Hats off to TFS I kind of wish I would have bumped up the CR a little now ... haha
Did you mill the heads at all or are they out of the box
Old Mar 12, 2008 | 10:51 PM
52172's Avatar
I sure hoped he milled them since you always benefit some from a slight mill the only reason heads come from their factory the way they do is so that you can run any cam of choice and not have to notch the pistons and with the altered valve angle you can run even higher compression than factory castings. Anyone that pays top dollar on a new set of heads and does not put a slight mill to them to get the right SCR and DCR is stupid. Most people are throwing their new heads on the factory short that can benefit from a head that has been milled. Especially with the more reclined valve angle.
Old Mar 12, 2008 | 11:22 PM
Websy21's Avatar
Very nice! AFR isn't the only head that makes great numbers!
Old Mar 13, 2008 | 09:45 PM
ramairroughneck's Avatar
Guess the lobes and mill are a secret. Highlift?
Old Mar 14, 2008 | 01:07 AM
GrannySShifting's Avatar
Have to guess its an agressive intake lobe, thats why I asked because it looks like its floating pretty harsh past peak. Making real good power up to there!
Old Mar 18, 2008 | 09:23 AM
mike c.'s Avatar
Is this camaro a m6? 12bolt w/ gears or stock 10 bolt?
Old Mar 18, 2008 | 10:21 AM
mikey's Avatar
LS1TECH Sponsor
10 Bolt with 3.42 gears.
