408 results
Well I am not sure what to think yet, So give me your opinions. 431/369 corrected on a mustang dyno. Heres the set up:
408 ( built for major spray) 12:1
Dart heads (Some bowl work and clean up)
250's 260's cam
BBK Intake ( Killing me )
Stock TB
Kooks 1 7/8 race headers
Single 3" exhaust w/ three chamber muffler
Full belts w/ all stock pulleys and power steering
TH350 RMVB 4200 stall
9"
All on 91 OCTANE
I know I need to change the intake and definatly get some cut outs.
Also a/f was 11.8-12.2 with only 22* of timing
So please let me know what you think and if I should be disapointed or not.
I will try to post the graph in the morning
Thanks for reading
PS the throttle body and intake are killin ya.
250's 260's cam
Stock TB
9"
All on 91 OCTANE
Thanks for reading
I think your huge cam is killing your torque down low. (as said) Your intake/TB is killing power where did you peak 6000rpm? Your timing and AFR are on the rich/low side. Is it going to be on the nitrous tune all the time? The TH350 with that 4200 stall is eating some power too. All has been said before. I would be interested to see this motor with a real tune on it not a nitrous tune and an opened up intake and exhaust. I think there is more in it, Good luck!!!
Jon
Plus the motor only has about 200 miles on it.
It was peaking at 6300
The timing was set at 15 degrees when we started just to make sure it was going to detonate all over the place, bumping the timing up 7 degrees jumped the dyno up by 40/20
Also I am tuning this car myself and it is my fist tuning job so I'm sure that there is room for improvment there.
Thanks for all the positive responses!
Jon
Jon
OP...keep up the good work and finish your tune.
There's more power there, good luck!
