Average numbers? MS4, PRC, A4
Old Mar 11, 2008 | 11:19 PM
02NBMWS6's Avatar
Well, I got the M6 driver mod down, I imagine this will be a walk in the park
Old Mar 11, 2008 | 11:35 PM
venom ws7's Avatar
Nice cars and numbers man so are you keeping T/A M6??
Old Mar 11, 2008 | 11:44 PM
02NBMWS6's Avatar
yes sir!
Old Mar 12, 2008 | 12:22 AM
venom ws7's Avatar
Its funny that your DD/Street car is an A4 and the drag car is M6
LOL
I like it this way.
So what is the new setup on the beast??
Old Mar 12, 2008 | 12:27 AM
02NBMWS6's Avatar
LOL
I like it this way.
Yea, traffic sucks with an M6, and the A4 hooks way better on the street!
Without giving up all of the details, it's going to be a 4xxci high compression N20 motor
Old Mar 12, 2008 | 12:57 AM
BayAreaSS's Avatar
Damn man you are really going to have 2 beast! And they both look good. Looks like single digits are on the way for the T/A
Old Mar 24, 2008 | 05:03 PM
02NBMWS6's Avatar
Originally Posted by ThirdGenLS1
yea a ported fast should gain you anywhere from 20-30
FAST is installed, as well as a Fast Toys 85mm air lid and the car's been street and dyno tuned. The results were 10hp and 10tq across the entire rpm band from 2500 to 6500. Just slightly higher curves of hp and tq that looked identical to the previous tq and hp curves.
At first I was a bit disappointed with 10hp being the peak gain, but seeing how it picked up over the entire band, i'm pretty pleased with the gains, The car pulls noticeably stronger
Got it to the track on Saturday in the 4k+ DA and it ran a best of 11.86 @ 114 on a 1.70 60' on the first pass. I made a couple other runs but between me and the torque converter we found a way to f all of those up, lol. The next best was an 11.9 @ 114 on a 1.76 60'
I wonder if it would quicken with a PT4400 and some better DA...
Old Mar 28, 2008 | 04:29 PM
LIL SS's Avatar
Moderator
Any idea what the car weighs? I'm going to the track with my 63 C10 Pick up on the 4rth through the 6th. I'm making 430rwhp with a slightly different set up through a 4L80E with a 4,400 verter and 12bolt/3.73's/30x13.50 ET street weighing in at 3,800 with me in the truck.
BTW, my set up peaks at 6,550 (430rwhp) with the TREX and stock LS6 intake ported TB.. TQ peaks at 4,900 (387ftlbs).. I do want to go fast at some point.
Old Mar 28, 2008 | 05:09 PM
odarabla's Avatar
My buddies 2001 Formula made 463rwhp through a stock converter A4 and stock rearend with the trickflow 215cnc ported heads, F14 high lift cam and a fast 90/90 setup. My car made 423rwhp through a slpping tranny. Mods in my sig.
Old Mar 29, 2008 | 04:33 PM
02NBMWS6's Avatar
Whatever a full weight f bod weighs, i havent had it weighed but i havent done any weight reduction.
I'll be curious to see how yours runs
Old Mar 30, 2008 | 10:20 PM
LIL SS's Avatar
Moderator
Full weight F-bod should be a couple hunderes lbs less than me with better aero. I'm hoping to go 11.8x on the motor, but we'll see..
Old Apr 1, 2008 | 11:25 AM
  #32
fueledpassion's Avatar
Originally Posted by Kingc8r
Plus you have to have the driver mod. Not as much as a M6 guy...but it still helps. It's funny 400-420hp on here should be in the 11'2 but I see guys at the track with that much hp running 12.4-12.8s
eh, if you have a street car w/ normal street tires then the only thing you should be concerned w/ is the trap speeds. That's all I care about, because I have a 6 speed w/ stock tires. So clearly my car is not best suited for a drag strip. However, the car will still run really good on the highway.
Old Apr 1, 2008 | 01:32 PM
  #33
junior28570's Avatar
From what I've seen, your dyno numbers look about right for your mods. Def. not too low. However, your mph seems a little low for your dyno numbers. Some dyno's are just very generous. I would expect a full weight A4 430rhp/380+rtq car to run 11.3X @ 117 +/- 1 .. at least (if you have any kind of decent DA).
The higher stall will certainly help your 60' a LOT .. and your ET.
Just my .02
The times in my sig are w/ putting down 404rwhp and 370rwtq.
Old Apr 1, 2008 | 01:45 PM
  #34
02NBMWS6's Avatar
Just my .02
The DA was above 4k that day, and I was also having issues with the converter. Ive got a Vig 4200 with multi disc clutch waiting to go in, and hopefully i'll have some better weather soon and i'll get it back out to the track to run a decent number. I think locking the converter on the big end will bring the mph and im SURE the big Vig will drop my 60's nicely. Not to mention CA Speedway just sucks and is uphill, lol
