Ehh, Im somewhat dissappointed.
Old Mar 31, 2008 | 08:56 PM
04ctsvfl's Avatar
Default Ehh, Im somewhat dissappointed.
2004 cts-v
ls6
Although the V normally doesnt dyno as high as 01-04 z06's (why I dont know) Im still somewhat dissatisfied. Shouldnt I be making more power?
k&n flat panel
TB bypass
Tr-55 plugs
Kooks 1 3/4 LT's
No cats
Magnaflow exhaust
Dyno Tuned
I do have an odd raspy flappy exhaust note, Im running around 24* of timing I believe. And the air fuel seems good. Any ideas? would adding a 160*Thermostat and Msd wires do anything? Im also thinking about a pnp throttle body. I also have this 4 inch aluminum intake tube (for some reason the tuner told me to stay away from it because of heat soak?) but my stock tube gets awfully narrow squeeze even worse than the stock gto intake tubes. So Im at a loss. What could be wrong? Torque was at 342
Old Mar 31, 2008 | 09:23 PM
jetlag's Avatar
I know not the same, but my auto LS2 GTO put down 359 with the same mods...
It could be your 19" wheels weighing you down...
Old Mar 31, 2008 | 10:04 PM
04ctsvfl's Avatar
that would affect the dyno? I believe they are lighter than stock, but an inch bigger so more rotating mass.
Im through a 6 speed tho....isnt the auto supposed to take at least 10-15 away?
Old Mar 31, 2008 | 10:16 PM
Gordon0652's Avatar
I would say the wheels, what was your TQ?
Old Mar 31, 2008 | 10:19 PM
04ctsvfl's Avatar
I dont know, Im wondering why thats not on that graph. Ill find out tomorrow. Thats more important anyway right?
Old Mar 31, 2008 | 10:31 PM
sworaz's Avatar
Nice numbers, great looking car too.
Old Mar 31, 2008 | 11:11 PM
04ctsvfl's Avatar
I was hoping for at least 10 rwhp more. And thanks for the compliment.
Old Mar 31, 2008 | 11:14 PM
Gh0st's Avatar
Jedi Master
I dont see the problem here
Old Apr 1, 2008 | 02:23 AM
odarabla's Avatar
I also think that are good #'s for your mods. Throw H/C setup on that thing and really wake it up!
Old Apr 1, 2008 | 09:37 AM
PewterScreaminMach's Avatar
It's a bit lower than I thought it would be, but not "something's clearly wrong" low.
Old Apr 1, 2008 | 09:52 AM
lilbuddy1587's Avatar
19" wheels and IRS. Power looks good.
Old Apr 1, 2008 | 12:26 PM
Frost's Avatar
The numbers look fine to me.
The graph looks like it does (against MPH rather than RPM) because they likely had a hard time with the spark signal hookup.
Old Apr 1, 2008 | 12:29 PM
04ctsvfl's Avatar
what does that mean? should I check my spark plugs. Does this mean he didnt touch the spark tables.....Please explain. Thanks
Old Apr 1, 2008 | 03:05 PM
Frost's Avatar
uhhhh the spark signal hookup for the dyno, it doesn't have anything to do with your car except that these late model GMs can sometimes be a lil difficult for that dynojet to get a good spark signal reading from.
Old Apr 1, 2008 | 03:31 PM
04ctsvfl's Avatar
ahh alright, sorry im a newb.
Is it possible one of the spark plugs could be fouled up? Or would he still of seen that with his readouts?
Old Apr 1, 2008 | 03:55 PM
nvmy2000ss's Avatar
These are good numbers. I had a buddy that dynoed right about the same. we were a bit dissapointed as well but thats about normal.
Old Apr 1, 2008 | 04:33 PM
04ctsvfl's Avatar
nvmy.....in a V? with full exhaust and a tune?
Old Apr 2, 2008 | 10:23 AM
Frost's Avatar
Originally Posted by Frost
...it doesn't have anything to do with your car except that these late model GMs can sometimes be a lil difficult for that dynojet to get a good spark signal reading from.
Old Apr 2, 2008 | 11:00 AM
trukk's Avatar
Fla,
You've also got to remember that no two dyno's are the same. Do you have any other V's that have used that dyno to compare to? If not I wouldn't sweat it. Dyno's are there to stroke your ego only, if you aren't using it to compare progress from mod to mod.
In december after having my ported fast 90/90 installed, I dyno'd at 378 on a local mustang dyno (FBC's mustang 1100). 10 days ago I went across town to get a baseline beofre my cam install on another dyno (PSI's mustang 1100), and with the same mods, I dyno'd at 355.
It's all relative, don't worry about it.
If you REALLY want to know where you stack up, go do some 1/4 passes, and look at your MPH, and post it up. That will tell the story.
-Chris
Old Apr 2, 2008 | 11:24 AM
04ctsvfl's Avatar
Word. Thanks Trukk
