Vindicator "cam only" Z28
Old Apr 14, 2008 | 01:44 PM
AlexLs1's Avatar
I'am pondering about changing cams, this one I'am looking into, I really like it, this just adds to my list favoring it.
Thanks for posting, and nice numbers.
Old Apr 14, 2008 | 02:19 PM
98_Formula's Avatar
nice numbers, esp for not getting a dyno tune on there. how was your PTV clearance with stock heads?
Old Apr 14, 2008 | 03:14 PM
svodave's Avatar
I don't know. They (Vengeance) said it's very close with this cam. I figure as long as they never touch it makes no difference to me. I'm just a shadetree mechanic though. Vengeance said it would work with stock heads and it does.
Had it in since August '07 with no problems so far.
Old Apr 14, 2008 | 03:22 PM
98blueSScamaro's Avatar
yes it will work but it is very close with the stock heads. so close to were if i was spinning the motor past 6700 i would be biteing my lip i am using the stock 243's and they have more room to work with. But other wise love this cam and it not bad to drive at all with a m6
Old Apr 14, 2008 | 03:35 PM
svodave's Avatar
Here's the graph.
Note the dip where it's running rich, then makes more power as it leans out some.
Old Apr 17, 2008 | 06:18 AM
2001z's Avatar
i just ordered the vindicator 2 cam and it is supposed to have a little more clearance than the vindicator 1 cam.
Old Apr 17, 2008 | 07:09 AM
ScreaminRedZ's Avatar
registered user
Damn good numbers for a mail order tune! From the videos I've seen that cam sounds increadible.
Old Apr 23, 2008 | 07:13 AM
s346k's Avatar
how does the car drive with the stock rear gears?
Old Apr 29, 2008 | 04:28 PM
Shredder_Z28's Avatar
a FAST 90/90, or the new 92mm will help ALOT for a cam that size. a ported FAST combo would help even more! On a vindicator setup with a ls6 intake, Vengeance had the rev limiter set at 6,900. with a ported fast 90 combo the rev limiter was set at 7,200. There have been some pretty insane # increases from the FAST swap, its just so damn expensive! just a little food for thought
Old Apr 29, 2008 | 07:25 PM
Vengeance Racing's Avatar
LS1TECH Sponsor
Should lay down about 420RWHP with a final dyno tune and a 10 min cool down.
Good luck!!!
Old May 4, 2008 | 01:54 AM
svodave's Avatar
Good luck!!!
Agreed! Thanks for the fantastic customer service over there. Ron has been very helpful every step along the way. I would recommend Vengeance to anyone.....
....well, anyone who wants to order a part- receive that part quickly and correctly- install it with no issues- and have it perform as promised.
Old May 7, 2008 | 08:08 PM
  #32
LS1TECH Sponsor
Glad you are happy man. When you are ready for a ported 92 combo give us a call and go for another step in the right direction.
Old May 7, 2008 | 08:28 PM
  #33
neeshSS's Avatar
I'll have that 92/92 on top of the vindicator here in few days. We'll see how she does!
