Anyone with an SLP 402 please come in
Old 04-15-2008 | 09:37 PM
ExceSSive's Avatar
I went with the racetronix fuel pump and the SVO 42#...if you make anywhere over the power you have now the 30# will not be enough. If you get the harness with the racetronix fuel pump you can later add a boost-a-pump and to add fuel pressure to make the 42#s bigger.
Anywho, I guess I am saying that I would not use the 30#s or the stock fuel pump.
Here is a Link I found helpful when picking my fuel system.
Old 04-15-2008 | 10:18 PM
allngn_c5's Avatar
Originally Posted by algws6
are you just upgrading or did something happen to your motor?
A combination of both. I was experiencing a good amount of blow by last year and LGM installed version II of the g5x3 cam, a ported 90 combo and also added a c5 zo6 MAF. After a retune she put down 490 rwhp 445 rwtq up from 457 rwhp 417 rwtq, so with the new results and also a compression test / leak down test all coming back good we thought she was fine. With that being said, between the power she's making and how hard I push my motor I think she just quit on me. Consuming coolant, and a new mysterious oil leak that wasn't present until about 300 miles after I changed the oil after getting her out of storage. Blow by was worse, white and blue smoke was coming out the back. I rode her hard to many times and she finally said F&*K off . LOL.
Old 04-15-2008 | 10:26 PM
allngn_c5's Avatar
Hey excessive thanks for the inj/fuel pump link and comments. I'll be talking to LGM tomorrow about that and get back to you on it. Actually I am going to email them now. Anthony is very good about getting back with ya.
Old 04-16-2008 | 01:47 AM
grimloc3's Avatar
Im running the stock fuel pump and a boost a pump set at 20% on my setup without any issues. For injectors i went with 42lb svo's and i have pleny of room left for fuel. I think if you stick with the 30lb injectors you will be pushing them to the max.
Old 04-16-2008 | 04:00 PM
allngn_c5's Avatar
Thanks for the comments on injectors and fuel pump. You made damn good power, 550 rwhp 500 rwtq !! Do you have a graph you could post ?? I don't think I'll be seeing 550 rwhp considering my AFR 205's being reused on the bigger motor. Ron did port a 92mm FAST to 95mm and matched a 95 mm TB to it, so that should help a bit, I hope. LGM's big 3 will be replacing my bullets to create a true 3 inch exhaust with no bottle necks. Hopefully I will see 520+ rwhp and 490+ rwtq. I'd be happy with that !!!
Old 04-16-2008 | 04:43 PM
mike c.'s Avatar
Hay Doug,
I seem to remember a post about a year ago and the guy did what you're talking about. He took all his parts,heads,cam,ect off his 346ci and added them to a 402ci. He gained like 25hp just from the CI's but I don't remember how much tq.
Old 04-16-2008 | 10:40 PM
allngn_c5's Avatar
Mike, I remember two possible tech members that did something similar. MSGuff and Gannon if memory serves. One had AFR 225's though and made a few more rwhp. I think MSGuff was the one with 205's and did 490/490 with neck snapping throttle response. Again tapping my memory he had FLP headers. Not the best of choices but still got good results. I'll have a larger intake (ported 92 to 95mm with 95mm tb), and better flowing exhaust so I am hopefull that my numbers will be a bit higher.
Old 04-17-2008 | 01:15 PM
grimloc3's Avatar
Sorry i don't have a graph with me right now and thanks to my current desert vacation i wont be able to get to it for a while. I don't think you will have any problem making 520 with the setup your planning
Old 04-17-2008 | 02:12 PM
allngn_c5's Avatar
Grimloc3, I see Vengeance did your motor. Do you know what the compression is, and what cam you are running?? I would guess the vindicator is in there, or a custom bigger cam. What injectors did Vengeance use ??
Old 04-18-2008 | 12:52 AM
venom ws7's Avatar
A friend if mine beat the living hell out of SLP 402 With Nitrous and 8psi Vortech
For two years with crappy tune too after that he cracked a pistons.
Good short block.
Good luck Allngn I'm sure you'll get 520hp and the TQ Will rise with 56ci so 490tq is not a problem IMO.
Keep us posted.
Old 04-18-2008 | 01:46 AM
allngn_c5's Avatar
Thanks a lot bro.
Old 04-20-2008 | 10:04 PM
  #32
The Alchemist's Avatar
UNDER PRESSURE MOD
I'd be surprised if the SVO 30's would be enough. I checked a recent log and I'm at 83% right now and not excatly sure what power I'm putting down, but I'd have to guess around 450-465. If you're currently putting down 490, you've probably already maxed them out.
The last thing you want to do is hurt your motor because you ran out of injector.
Old 04-20-2008 | 10:47 PM
  #33
allngn_c5's Avatar
I spoke to Anthony@LGM about the injector question and he too thought that the next size up injector would be a good idea. He also said to not worry about the stock fuel pump holding up. Just need to get some bigger injectors. I'll get back to you in a couple months when this project starts coming together.
Old 04-20-2008 | 10:51 PM
  #34
allngn_c5's Avatar
As far as my current setup maxing out my injectors, it not. Still some room left, but not too much. 5% left maybe a bit more. So you add another 30 rwhp and 50 rwtq by stepping up to a 402, the 30# injectors probably won't be able to keep up.
Old 04-21-2008 | 12:43 AM
  #35
ExceSSive's Avatar
Do you mean you are at 95% or 75% with your current injectors? Everything I read says you should only stress your injectors to 80% duty cycle. I would say if you are WOT and hit 85% or 90% is OK but if you are WOT much of the time I like the 80% rule.
Old 04-21-2008 | 09:43 AM
  #36
allngn_c5's Avatar
I am assuming 5% from being maxed out on my current setup. Just going off memory. I could be wrong.
Old 04-27-2008 | 12:35 AM
  #37
helicoil's Avatar
Was he suggesting a 37lb. hr would do the trick for your 402?
Old 04-27-2008 | 06:02 AM
  #38
allngn_c5's Avatar
I thought he said SVO 36#
Old 04-27-2008 | 08:27 AM
  #39
mike c.'s Avatar
Hay doug,
got my 402ci l92 back from Kirk 517hp 466tq....need a fast intake now.
Old 04-27-2008 | 12:55 PM
  #40
30th t/a's Avatar
Originally Posted by mike c.
Hay doug,
Nice Numbers Mike! this is on the stang dyno right?
