H/C Headers done dyno #s
Blackwing, 85mm Maf with hiflow airbridge, LS6 intake, LS6 injectors, untouched Z06 243 heads, Cometic .040 gaskets, TSP228 114LSA cam, Comp 918 springs, LS7 lifters, 7.350 pushrods, LS2 timing chain, LS6 oil pump, LS2 pulley, LS3 water pump, KOOKS with hi-flow cats, flowmaster catback. Mike Norris came down for the dyno tune. Let me know your thoughts.
Good talking to you the other day for sure. Just let me know when you want to get together. I would really like to do a cold start scan and look at everything. Should be a simple fix, but I would be sure there are no vacuum leaks or misfires before we do anything.
On the lean Air/fuel look, the pump for the sensor is not working well at the shop I use and the sensor is about 6 feet from the end of the tailpipe the way it is set up. So there is quite a delay from when I hit the sample button to when the sensor reads the change from a cruise AF to the WOT AF. I do want to fatten her up a little at the midrange. But on the top end there was some KR and I personally see more power with a richer AF and more timing then I do with shooting for a perfect 13.0 and less timing. Not everyone agrees with this, but it works for me most of the time.
Also when traveling to tune it is quite different then coming to my shop in that is there is an issue I do not have the facilities nor the extra time to start checking things such as plugs, oxygen sensors and harnesses and so on that may have an issue with the install.
Best to all.
Mike Norris
