E85 vs regular gas dyno
Old Jun 4, 2008 | 03:11 PM
  #61
BOTTLEFEDLS1Z's Avatar
Originally Posted by Ryan L
Was this n/a and was the a/f ratio and timing the same on both runs? Your results don't make sense, IMO.
I'm running 2* MORE timing on E85. Thats it, the car wasn't, making any power above 27*.The car is 13.2 AFR N/A on both set-ups!!!
Originally Posted by ls1408cp
this is my friends car and nothing was changed but the tune. The same guy tuned it both times on the same dyno. I would guess more timing was added with e85.
LS1408CP was present while this tuning was going on.
Old Jun 5, 2008 | 07:02 PM
  #62
sslateron's Avatar
Sounds pretty sick, so its race gas at a deep discount! lol
Old Jun 5, 2008 | 07:43 PM
  #63
Basically, just gotta be careful with the winter blend of ethanol as its not as high of a octane as spring/summer
Old Jun 6, 2008 | 04:26 PM
  #64
rons 00z's Avatar
why would you want your AFR like that? stoich should be 9.7 on e-85. did you change your afr on your wideband so 1 lambda was reading 9.7 instead of 14 like regular gas?
Old Jun 6, 2008 | 05:59 PM
  #65
My tuner adjusted the AFR accordingly. Yes you are correct though
Old Jun 6, 2008 | 06:38 PM
  #66
nick1ta's Avatar
Hey dan, whats up?
