dyno today for the 408
or the one that have been proven over and over
imthinking about taking him to court
You posted the craigslist ad exactly 2 hours after making this thread, and according to your ad, there is nothing wrong with it....so whats the real story?
You put your car up for sale 2 hours after your first post in this thread and in the listing you don't mention a single problem with the car! http://detroit.craigslist.org/car/661119114.html
You even said this in your ad: " idles nice and drives like stock".
Hmmm.. that's funny. You don't mention that in your add!
I got news for you. If your injectors flow 36lbs at 48psi you would have to increase your fuel pressure to 100psi to make them flow 52lbs per hour. So again, I call BS on your injector size. Which is it? 36lbs like you say here or 52lbs on your ad?
So then you put it up for sale and don't mention a single problem.
Come on, sounds fishy!
Just so people can read what you wrote on CL here it is, word for word ( Just in case you edit your CL ad ):
i took a loan out to buy this car and to give me some money on the side to build this up but i recently just lost my job and defaulted on my loan now my interest rate is threw the roof and i'd be paying close to twice the amount i borrowed so i need to sell this. im open to offers but their is alot of work into it. so please no low ballers and no joy riders. i built this car to be mine forever but need to sell it so it does not get taken away. i am leaving out prolly a few things alot the lines of whats done to it but this is what i can think of
heres a video of it idleing pretty well before it went to get tuned http://youtube.com/watch?v=Rm4yJfhtKXg
the car is a deep red looks sunset orange metallic in the sun, has halo headlights, clear corners and aftermarket foglights, has silverstar headlights. the t-tops do not leak and the car is only driven in the summer, it has the ss spolier on the car. has a set of 18in rims with 2k miles on them and the tires.dark gray lether interior
the following stuff was just done over the winter alot of things were sandblasted and painted so theres no rust
car has poly motor mounts,poly trans mounts,will throw in a case of amsoil synthetic oil.
engine: iron 6.0 block bored .030 over 4in stroker crank makes it a 408 CI 6.7L. has a eagle crank and rods, diamond forged pistons.11:1 c/r run on 93 octane. cam is a 236/236 .617/.608 114lsa idles nice and drives like stock almost. heads are new from the ls3 corvette has trick flow pushrods and ls3 rocker arms. intake is from the ls3 and has a holley 90mm throttle body and brand new 52lb injectors. Headers are hooker 1 7/8in 3in true duals over the axle with a x pipe and spintech mufflers.
trans 6speed with a ram heavy duty clutch, adjustable mastercyclinder, new flywheel,new slave cyclinder, mobile 1 synthetic atf shifts like a dream.
brakes: all calipers rebuilt and painted has ceramic brake pads all around and all new rotors.
suspension: has eibach lowering springs on it gives it a 1.5in drop new stock from shocks and edlebrock rear shocks has the eibach anti roll kit on it which consists of a 35mm front sway bar amd poly buchings and end links a 1in rear sway bar rear tubular control arms with relocation brackets adjustable panhard bar upper panhardbar relocation bracket for true duals over the axel.
rear end: stock 10 bolt but bought it off a guy who put stronger axels in it. has had synthetic mobile 1 in it the entire time
you either have experence with him or you dont, you cant knock the guys experence. If you have any experences w/CARS or can offer this guy some help then do, but getting in the middle of this and bash'n the guy is pointless.
As for it being my 2nd post and owning a mustang. I have owned a few. I joined this site back in 2006 because I wanted to swap a LS1 into one of them. I've also owned a 10sec Buick Regal, an 11sec FWD Omni and numerous 12/13sec cars. I don't post because I don't feel the need to. My LS1 plans changed.
Bashing the OP ( Who has lied ) has more merit than the bashing of a business owner whom has not been proven to have done anything wrong.
