highest 370 na a4?
Old May 4, 2008 | 05:53 PM
Patrick B's Avatar
Default highest 370 na a4?
What is the highest rwhp naturally aspirated a4 370cu with a hydraulic cam record?Thanks , Patrick
Old May 7, 2008 | 09:01 AM
Biggs's Avatar
Default 370's
Come on, there has to be a few good running n/a 370's out there.
Old May 7, 2008 | 05:54 PM
venom ws7's Avatar
I dont know the highest but PREDATOR Z made 462rwhp A4 with VERY VERY small cam and car drives like stock.
Myabe he will chaime in.
Old May 7, 2008 | 07:13 PM
allngn_c5's Avatar
Predator has a bad *** ride. Wins, wins, wins, when he races.
Old Aug 29, 2008 | 09:27 PM
KBOBOZ71's Avatar
i just made 484rwhp n/a in my 370 m6, that was on a mustang dyno too.
Old Aug 30, 2008 | 04:12 PM
StreetStalkerZ's Avatar
I made 447rwhp/402rwtq uncorrected on the same dyno KBOBOZ71 did with my A4 370ci iron block,converter was unlocked for the dyno runs. Probably looking at flirting with 500rwhp on a dynojet with a locked converter. Mods are in my signature.
Old Aug 31, 2008 | 04:08 PM
smok'nZ's Avatar
MASS seller approved
you both made good numbers esp for having an unknown tuner
Old Aug 31, 2008 | 06:11 PM
The tuner (Greg Mcbride) done mine and KBOBO's car. My numbers were with around 300 miles on the motor. Since then i have around 3,000 miles and added a 85mm lid,85mm MAF and 85mm BBK TB. Should dyno higher but i'm more into track times than dyno numbers
Just think what our cars would put down with a ported FAST 92 intake setup.....freaky numbers from an all bore bottom end.
Old Aug 31, 2008 | 09:24 PM
smok'nZ's Avatar
i talked to him about the guy who tunes them and i would have done the same thing instead of paying hi dollars to have it tuned and u both are on built drivetrain not stock 10 bolts and such
Old Sep 2, 2008 | 01:53 AM
PREDATOR-Z's Avatar
Well you can make over 500 rwhp for sure.
Mine is a DD, with cats, VIG 3800 stall, high compression, excellent throttle response, screams to 6800 rpm, quick reving. Could I get more, yes but my goal was stealth untill WOT and good gas mileage.
370s are good motors especialy for boost or nitrous (my addiction).
I'm a bit short of funds, but I'm gathering parts to Supercharge it soon.
214/230 .563/.571 114+1 cam
Bo White ported Stage 1 317s
2800 restalled Vig 3200
And a 7psi PS1 Procharger
370 LME built shortblock, Hellfire rings and 2cc Wiseco pistons.
Goal 550rwhp @ 6000 rpm (6300 shifts)
Old Sep 2, 2008 | 02:05 PM
Kingc8r's Avatar
^ should move out nicely
Old Sep 2, 2008 | 02:06 PM
smok'nZ's Avatar
he said NA im sure there are plenty of 600+ supercharged 370's but he want to know the all motor ones
Old Sep 2, 2008 | 04:30 PM
I think PredatorZ was just letting us in on his upcoming plans,sounds like it should be fast.
PredatorZ,my LME built 347 i had only last over a 1000 miles before it slung rods all over the track. I built my own 370 im my garage after that major screw up happened
Old Sep 6, 2008 | 02:05 AM
PREDATOR-Z's Avatar
I've had mine for 2.5 years and 3 cams in it, 250 shots of juice, 1.5 season of drag with the 2006/2007 UAE Super Street Championship, still running like a beast. Still no oil burning and good compression on all cylinders.
I have had 3 motors from LME, all of them still running.
Did you ever determine what happened?
Old Sep 6, 2008 | 08:40 AM
We both have our own version of what happened to the motor. It's a long story but i seen enough from them to know they suck ***! There are a few more of their motors that done the exact same thing. Someone posted another thread of a 408 doing the identicle same thing mine did in the moderator section,back when i was a moderator.
