Disappointed with cam only numbers... TV2
Car made 356rwhp and 340rwtq...
Tune is dead on and we have no idea where all the power went... It was kinda humid out, and the car burns a lot of oil so they were thinking it might have a bad piston ring...
Gonna do a compression and leakdown test sometime soon to make sure everything is in check...
What do you guys think?
I Checked the plugs today and did a compression test. Come to find out, the 4 plugs on the drivers side were barely hand tight, and one wasnt even hand tight...
I checked the compression and everything checked out fine. Every cylinder was at about 162, with one at like 158 and a couple at 165.
However, almost all the plugs were covered in oil, I think this is because I forgot to plug the MAF in after I sprayed the Deep Creep into the TB, so it fouled all the plugs.
Anyways, car runs a little better and smoother, but still burns a lot of oil and I think the tranny is slipping...
