HP drop on N20 Run
Old Jul 24, 2008 | 02:19 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default HP drop on N20 Run
First graph is boost only and second graph is on a 75 shot.
What is causing the HP to drop like a rock at 4000rpm? If I had trans or converter slip I could understand it plateauing but dropping? Bottle pressure was good but on a half fill. Could this be sucking air?
your thoughts please?
Old Jul 24, 2008 | 04:36 PM
toneloc60's Avatar
Just spit-balling here, but perhaps the drop in temp from the n20 caused your boost pressure to drop. Just a guess.
Old Jul 24, 2008 | 05:10 PM
trever1t's Avatar
I should have stated, Magnuson Radix M112 supercharger. The slope in boost is pretty average I think but I do appreciate the response. The "Magenta" lines are the last pull if that helps.
Old Jul 25, 2008 | 08:45 AM
trever1t's Avatar
any other thoughts?
Old Jul 25, 2008 | 08:56 AM
stevegrizzle's Avatar
Looks like a lean spike to me.
Old Jul 25, 2008 | 12:17 PM
trever1t's Avatar
Could be and probably is. Took the bottle out this morning and it weighed 18.4lbs (10lb. bottle) so there is only about 3 to 4 lbs. remaining after 4 runs. Possibly picking up some air?
Pressure of the bottle is still 800lbs in my 65* office
Old Jul 25, 2008 | 12:42 PM
ScreaminRedZ's Avatar
registered user
Am I the only one that hates these kinds of dyno sheets?
Old Jul 25, 2008 | 01:24 PM
trever1t's Avatar
no, you are not, lol. Here are some I find easier to read.
