PRC 2.5 LS6 Heads/Torquer V.3 and mods in sig...
Later this week I am installing an U/D pulley, Meizere EWP, and 42lb/hr injectors, and then getting the car retuned. I'm looking forward to seeing how much cooler the car will run and what if any gains might be had...
BTW, car looks great!!!
Damn, I can't believe how long that holds out peak power. It was still holding at the rev limiter. Are you gonna bump it up? If it holds that strong, even if it starts to drop holding it out to 7,000 RPM, you'll MORE than make up for that on the shifts when it hits in a stronger spot. That's just plain sick.
By no means did I mean to offend you, and it certainly doesnt sound like you took it in that manner. I guess I just expect people to be making noticablely more power running a larger cam and heads over my Patriot Stage II 59cc heads, and Comp 224/.581 112lsa cam. That's why I stated I was hoping you would be 460rwhp+...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Thanks! With the 225's and a ported fast, you should be there...make sure u post it.
LS1Tech Premium Sponsor
Thanks for the kind words on the heads! We've worked really hard to make sure the quality on our cylinder heads are absolutely top of the line. Just because the heads don't cost 2300 doesn't mean they can't perform very well!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
