FAST 92/92 swapped in
Every time one of these big intakes come in on a stock cube car, I hate it, cause they never pick up as much as the customer thinks they will. Been proven over and over... The bigger MAF might help, but the stock one usually flows plenty for cars of this power level. However, looking at the logs, the KPA was pulling back into the 95 column at higher RPMs, indicating a restriction in front of the intake...
The biggest power robber on this particular car is the converter - but I'm afraid to lock it up to show the difference and break it on the dyno... I say run it at the track and see what it traps. Then maybe try an 85mm and see if we can pull some more out.
1. Stingy Mustang Dyno
2. a4 built
3. stalled
4. geared
You don't have an aggressive setup at all bro. I would imagine an a4 stalled like you have it and geared must **** and git outta the hole !!! You want more power throw a bigger cam, a better set of heads. Other then that enjoy the neck snapping shifts you get when you put your foot down.
When everyone talks about getting a bigger MAF, is it better to get a whole new unit, or do the aftermarket housings with the stock internals work well?
I just wanted to post this up so people can see that the FAST intakes don't always gain big numbers. I hadn't seen many posts on here about that.
Also, to everyone else - take this as a lesson. Don't go with a converter unless it's one of the proven names. You may save a little money, but you sacrifice a lot of quality. I'll be switching from my Performabuilt 3600 to a Vigilante 3600 in the future.
I would be curious about the converter efficiency. Have you log the engine rpm versus the trans input rpm? That will tell you the efficiency of the converter, if it is less then 80% it is the converter and would explain the low numbers. Also locking would reveal if it is the converter. The stock clutch (used in those smaller aftermarket converters) will take a run from 3000 to 6000 rpms if locked before going WOT. I have done it many times on different setups. Going WOT while it tries to lock is what kills the material. Just my suggestions.
old exhaust was slp loudmouth II
new exhaust cut out and then a moroso sprial flow, then 2.75" pipe thats dumped over the axle
It does seem like the dyno has been extra stingy lately!!! When things slow down this fall, I'm going to get the shop owner to send the load cell in to get refurbished or replaced, and get the dyno recalibrated.
On another note, have you considered going with a little more cam in the future??
