70 NOVA with 6.0
70 NOVA with 6.0
What will it run,my combo is stock LQ4 short block,lunati cam with 244 duration @ .050 and .609 lift on intake and exhaust with 112 lobe sep,L92 heads out the box no port work,carb intake with 850 holley,msd box to fire coil packs,1 3/4 headers with 3 inch exhaust and flowmasters,powerglide 4500 converter with trans brake,513 gears with 29x9 slick,car weighs 3300 with me in it.The same set up with 355c.i. solid roller ran 7.0 sold that mtor to try this ls stuff out,I am hoping for around the same numbers but with pump gas.Any info will be appreciated.
Should go low 11's in the 1/4mi easy. Not sure what that calculates into in the 1/8mi though? I think it might be in the same range. Toss a lil spray at it and it should break into the 10's with a small shot (75-100)
Yeah I might have to toss the 513's for some 411's I have a set of them just in case,the small block I had in it I was shifting at 7600 but it also made it through the eighth on a 325 shot with a big shot plate,it ran 6.18 @114 but it was @ 8000 through the lights.It actually slowed down with 411's with that motor,the reason I think it works better is because the 1.76 first gear of the glide.I think I will be shifting this motor around 6500 to 6800.
