View Poll Results: Which is better? 500rwhp N/A, S/C, Nitrous, or Turbo
Voters: 67. You may not vote on this poll
N/A power vs. FI
are you taking driveablility into this equation? cause THAT would be an interesting disscussion, fast on the track and skreet, AND pull through a mcdonalds, order some mcnuggets in the drive thru with the air conditioning while playing the stereo
if that was the case, N2O all the way, drives like a kitten, then flip a switch and its a tiger.
no, the op says NOTHING about driveability...i'm not trying to be a dick, but you guys need to read the post
So you're allowing that different combinations will bring drastically different curves, however, peak levels will be the same? You mentioned power numbers, but said nothing about the torque these things make. You've got to get somewhat technicle because each one will act completely different.
The discussion has everything to do with power curves, cuz that's what really matters. And that's the point I am trying to prove with someone.
Sure we could get real technical and say each engine is different. Some need FI and some do great N/A...i think LS motors make great power N/A others may not and thats what i meant about getting "technical"
A 500Hp NA
I assume the discussion is limited to stock cubes..
500 hp NA is much easier today than when these cars were 1st built.
It's also more impressive to accomplish.
If done right, you get a car that sounds wicked, yet drives OK & gets decent milege.
The power is there all the time but without altering the basic arctecture of the car.
Nitrous is good until the bottle is empty..
A 500Hp NA
Agreed, nitrous and built motor. no contest. depends on "when" you spray though with n2o car.. centrifugal s/c and nitrous is a KILLER combo!
Spray for the low rpm torque boost then the centri kicks.. turbo guys do the same thing spray to alleviate the lag.
wow nitrous is that far behind? that is not right, nitrous car should be the quickest. even though a roots blower car makes great flat useable torque it will not be well above the hp rating like a nitrous car will be, in most cases, the same will be true with All motor cars. Most of them dont make lots more peak tq then hp.
#33
This is what happens when you're NA and you spray too early. With a centri s/c the S197 would have taken the Mach 1/Procharger F1A, built motor and 20+ lbs of boost.
Centri s/c high rpm power and spray (w/ strong rods/pistons).. perfect combo IMO.
http://www.youtube.com/watch?v=WRgenanUtOg
#34
i think nitrous would win off the line if you could hook with all the low end torque and turbo would trap higher...just my thought because of the torque curve. alot would depend how high you spin the engine too with the turbo. nothing feels as good as having a na engine tho
#39
As stated, we would be drag racing the **** out of diesels with 21 speed transmissions and other items to take advantage of that power band.
Overall power under the curve and Power past peak is what you want.
Spinning RPM is the last thing we want to do when it comes to motor life, but in essence, it is something we HAVE to do. We had a great discussion about this in the 500 cubic inch ERL thread that was made a month or two ago.
Think of Piston Speed, Ring reverberation, valvetrain, etc.
