HP est: LQ4, MS3 cam, milled 317s
Engine is going in a 00 Camaro, Its a LQ4, MS3 Cam, Milled 317s to 65cc(10.5:1 CR), LS3 intake, 90mm tb, full bolt ons. What do you guys think power wise?
I said 430 as a conservative estimate, but also consider, even though you milled the heads, that's still close to stock LS1/LQ9 compression, bit it was probably a good move for squeezing out the NA power out of the LQ4.
So that's my reasoning, and mainly so you don't get your hopes too high.
So maybe 440 rwhp would be a better conservative estimate.
Thats what i was thinking, would rod bolts be worth doing before the engine goes in? i remember hearing something about the ARP rod studs weighing more then the factory TTY bolts? the engine wont ever be sprayed, just want to have it hold up.
