What HP/TQ numbers should i expect?
Banging some gears
Well i cracked one of my stock heads over the winter so now im just getting the funds together and getting my car back goin..
I've now got:
Still stock bottom end
PRC stage 2.5 5.3 heads
Fast 92/92
42# injectors
Custom grind cam 231/239 600ish lift(not sure yet b/c i havent recieved the cam card)
TSP 1-7/8 LT coated headers
nitrous outlet 150 plate shot..
Anyone guess at what it will make on motor and on the bottle? I'm jsut curious to know
Thanks
Daniel
I've now got:
Fast 92/92
42# injectors
Thanks
Daniel
damn...you got the LSL cam?
i have about the same one...i think its .617/.623 lift. whats the lsa and advance?
our combos are going to be close. only i got prc 243's...
man, im anxious to see this, i think you have about the same cam as me. and my 243's vs. your 5.3's should be close....
only other few differences...
i need to get a fast intake.
you have 1 7/8 headers vs. my 1 3/4 (which on your setup will be worth a good amount)
also, is your car a m6 or a4?
Banging some gears
Premeir Autosports in Memphis, TN spec'd the cam out for me based of my car weight (3880 w/ me in the driver seat) gears(3:91) heads, intake, shot of nitrous, and a few more things... That is why im unsure of the lift and lsa at this time
Zacht---> My car is a 6speed
Banging some gears
224 cam only.. headers, lid, tune, free mods. i think it made 392hp and 383tq corrected on a bad tune up.. once i got a better tune i never went back to the dyno.. may have squeezed about 10more hp out of it at best.
my compression ratio is supposed to 11.25:1
I'd guess you'll be around 450-460rwhp and 400-415ish rwtq on nuts (SAE, dynojet) with the new setup.
My bad that's what it ran 224 cam only. I thought that's what the current setup ran. I ran 115 mph in 4000' da air with a raceweight of 3800 lbs. I was only making 411 rwhp at the time. I would think if I ran at a sea level track in -da like a lot of guys do I could have ran 120 mph. All dynos are different and my buddies head, cam, fast 90 m6 04 gto put down 407 rwhp on the same dyno.
