How much rwhp
How much rwhp
If anyone could give me an estimate on the amount of power this might put down on a dyno this would be great. I know there's a ton of variables but if anyone has similar mods I'd like to know.
1999 LS1 Camaro SS
90k miles
6-speed
MTI lid/ k&n filter
Pacesetter LT's
3" SLP exhaust
Ported LS6 intake manifold
Ported LS6 throttle body
LS6 fuel rails
LS6 injectors
TSP 228R cam
PRC valve springs
COMP hardened pushrods
Gold crane rockers
Solid lifters
HD LS2 timing set
Ported LS6 oil pump
Walboro fuel pump
NGK plugs and wires
NGK ignition
Spec stage 3 clutch
Spec flywheel
Tic adj. master slave
Hurst short shift kit
MT 315's
Pump gas dyno tune
Thanks!
1999 LS1 Camaro SS
90k miles
6-speed
MTI lid/ k&n filter
Pacesetter LT's
3" SLP exhaust
LS6 fuel rails
LS6 injectors
TSP 228R cam
PRC valve springs
Gold crane rockers
Solid lifters
HD LS2 timing set
Ported LS6 oil pump
Walboro fuel pump
NGK plugs and wires
NGK ignition
Spec stage 3 clutch
Spec flywheel
MT 315's
Pump gas dyno tune
Thanks!
