Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
What can i expect at the track
Old 11-14-2010 | 08:32 PM
atrain59's Avatar
Default What can i expect at the track
Im going to the track next saturday for the first time ever with a local car forum. I was wondering what i might run.
MODS:
BBK intake manifold
SLP LID
SLP bellow
HSW plate kit 125shot
timing tuner
MGW shifter
and a tune
race weight 3700lbs.
ill be running on 285/30/18 street tires. Im hoping to mid 12s but not really sure what to expect.Any in put would be great thanks.
Old 11-14-2010 | 10:52 PM
atrain59's Avatar
I also have a zo6 clutch. I know spinning is going to be a problem so I'm not hitting the spray til second . The rear end is completely stock, will be adding 3:90 gears this winter.
Old 11-15-2010 | 12:42 PM
atrain59's Avatar
Just relized I put this in the wrong section can someone delete it thanks
Old 11-16-2010 | 12:48 PM
Gaunt's Avatar
Before the shot, I don't see why you wouldn't be high twelves with even a semi-decent 60 ft.
Also, helps to know your track and elevation.
If you don't blow through the tires, and your rear holds, you can be pretty confident in a low 12 second pass. That's a potentially large if however.
Quick Reply: What can i expect at the track
