My build's power numbers and/or quarter mile? Take a guess!
Well my build is done and my Vette has its dyno day scheduled on Aug 5th. If you'd like take a guess what numbers it'll put down on the dynojet and/or what ballpark quarter mile time and e.t. you think it should run on street tires.
List of what I did to my use to be bone stock '00 Vette (36k miles): Flycut pistons, Torquer V3 cam (231/234 .643/.598 112LSA), PRC cnc'd stage 2.5 5.3L heads w/62cc chambers, LS2 timing chain, ported LS6 oil pump, LS7 lifters, 7.40" hardened pushrods, Comp cams rocker trunion kit, '04+ LS6 valley cover (pcv conversion), 42lb fuel injectors, LS6 intake, 85mm MAF, CAI, LS7 clutch and flywheel, 1 3/4" LT headers, 3" X-pipe, NGK TR55 plugs, MSD 8.5 wires.
Thanks
J.J.
Thanks
J.J.
Yes I'm going to run on some good street tires. Its a street car that I don't beat on much. For a while I figured to run on Nitto drag radials but I don't care about racing all that much anymore. But I do have a friend with drag radials that might let me use just to see what it'll really run.
Thanks
