416ci ls3 guesses!
Hey guys about to get my car all together, heres the specs
416ci 10.7:1
ls3 heads, hand ported flow 360cfm at .650 (these heads made over 720hp on a 438)
comp custom grind cam 235/251 .623/.623 with a 113lsa
ls7 lifters
prw roller rockers
all arp bolts
TSP 1 7/8" headers
3" true duals
ls3 intake with fast 92mm tb
Nano Nitrous with hsw 92mm plate kit (spray 150-250 depending on what the plate allows may have to step up to a Nitro Dave plate)
4l80e Trans with a FTI 3800 spec'd out for the car
Car will be all tubular suspension from bmr, K-member, upper and lower control arms, sfc's, lca's, ta, phr, etc etc.
Whats your guess on power and what it should run at the track? should weigh in at 3250-3350lbs with me in it..
416ci 10.7:1
ls7 lifters
prw roller rockers
all arp bolts
TSP 1 7/8" headers
3" true duals
I'd def be fine with 550rwhp.. im hoping to just break the 500rhwp mark with the 4l80e. Forgot to add I will also be running a FTP 98mm lid and a 85mm maf. This is in a 01 Camaro SS as well..
