What hp will i have with my setup
I have a 98 camaro ls1 with a lingenfelter GT2-3 cam kit 243 milled heads a bbk ssi intake long tube headers and a k&n? Do i need to change injectors?
you could also use the 36lb injectors out of the pontiac gtp's, they will do fine for what you have but if you ever wanna make more horse power i would say go with the green top 42lb injectors.
well that cam is 207 / 220 .571" / .578" 118.5 lsa so it's on the smaller side as far as ls1 cams...
it would be a good Daily driver cam and very quiet, with a good tune I think you could hit 370-380 hp with it?
You might want to go a little bigger, you can go up to a 224-226 and still have stock like driveability and more power everywhere... but the cam you have will work good..
