Whats your guess?
so the motor for my car is starting to go together and just wanted to see what some of you think it will make.
details:
- - TEA 5.3L Ported Heads (casting 706), 59cc
- - Flow #'s LIFT -- INT -- EXH
CFM - CFM
.100 -- 66.5 -- 57.7
.200 -- 138.3 -- 122.3
.300 -- 204.3 -- 180.4
.400 -- 255.9 -- 220.2
.500 -- 293.3 -- 246.5
.550 -- 307.3 -- 253.2
.600 -- 315.1 -- 259.1
- - 2.02 Intake Valves, 1.55 Exh Valves
- - Comp .650 Lift Springs, Titanium Retainers
- - Comp Cams 235/242 - .620/.593 - 111lsa
- - Racetec Forged Pistons / Rings
- - 11:1 comp ratio
- - Scat H Beam Rods
- - Comp Pro Magnum Roller Rockers 1.75 Ratio
- - LS6 Intake
- - Bosch 45lb Injectors
- - Hooker Longtubes, with Jet Hot ORY
- - Magnaflow Cat Back
- - Ported Throttle Body
- - Rollmaster Double Roller Timing Chain.
- - Mantic ER2 Clutch
- - Strange S60 w/ 4:30's & Spool, 35 Spline Axles, BMR Adj Welded on LCA Brackets
details:
CFM - CFM
- - 11:1 comp ratio
- - LS6 Intake
