**Official 2014 Event: SRK "Loser eats Crow" Challenge**
BTW, if you would like to use this thread to chat or bs about the event you can. I'll be updating the first set of posts with results as they are posted here so that it stays organized
I feel like there will be alot of switching for top 3 in the 12 and 11s group as we dial in things.
Now, since not everybody will get to run the same track with the same air etc, should we do a "best corrected" number? I think that drag times DA calculator has a corrected times calculator.
-Numbers are final, no calculation for DA, deficits or bad runs. No phantom timeslips(bag blowing across beams)
#35
I thought about this and I have to put my foot down and say no for the reasons of keeping it simple and definitive. What's on the slip will have to be final. If you can run early spring then do it. If you are waiting for the perfect day than that is risk of running out if time. Some guys will get an advantage such as the east coast people, but then again they won't get out from under the snow until may at this point.
#36
I'm thinking there is a 10% chance I get into the 10's on motor/street tires. I'm planning on running at least a 75 shot some time this year, don't know if I will use it at the track though.
#37
#38
All I need is one good warm sunday and a little bit of luck. Ill definately be in the slower 1/3 of the 11's though.
#40
