Power estimates for engine build
I suppose I am just modifying the motor, rather than a full build. But I am getting ready to do a H/C/I swap with long tubes and ory. With a proper tune, what RWHP figures would you guys estimate?
Stock 98 bottom end
Slp lid
TFS 215 genx heads w/ Yella terra 1:7 rockers
FAST 102 intake
NW 102 throttle body
36 lb injectors and racetronix pump
TSP MS4 cam
TSP 1 7/8 long tubes and ORY
Stock 3.42 gears, will change to 4.10 as funds allow.
Stock 98 bottom end
Slp lid
FAST 102 intake
TSP MS4 cam
I have a melling high volume oil pump, since it's not a fresh motor and has the smaller 98 oil passage. I intend to go with TSP .675 double springs due to the high lift. Arp head studs and intake bolts. Probably a racetronix fuel pump.
Transmission was trashed when I got the car, so I am having Jason at TDP build a Magnum and retrofit it for the fbody. I suppose the rear end will be next, whenever it happens to go.
