Any guesses on power
2009 Pontiac G8 GT
Stock L76 6.0 block and rotating assembly
Improved Racing crank scraper
Improved racing oil pan baffle
Cam Motion 224/236 .629/.619 112+4 LSA
Blueprinted Melling M295 oil pump
25% under drive pulley
Kook 1 7/8 long tubes
Corsa header back exhaust
Peak speed radial ported intake
Peak speed ported 92mm TB
Granitelli plug wires
NGK tr6
Street/strip port on l92 head, backcut stock valves and valve job
BTR springs
Morel lifters
BTR pushrods
Comp trunion kit
LS9 gasket
ARP bolts
Trickflow 4-port steam pipe
ZR1 52lb injectors
LS7 MAF/Rotofab intake
FTI 3600 triple disk
Stock 6l80
stock 2.92 rear
NGK tr6
BTR springs
Morel lifters
BTR pushrods
Comp trunion kit
LS9 gasket
ARP bolts
ZR1 52lb injectors
Stock 6l80
stock 2.92 rear
