6.0 LSA blower
6.0 LSA blower
combination is as follows:
6 liter LY6 (coml 9.6:1)
Factory ls3 heads
Ls9 cam
Stock 1.7 rockers
Stock LSA crank pulley
TVs 1.9L blower
Stock upper pulley (8.8psi)
6 speed t56 magnum
3.55 rear end
Curious as to what you all think this will put down to the wheels?
Factory ls3 heads
Ls9 cam
Stock 1.7 rockers
TVs 1.9L blower
6 speed t56 magnum
3.55 rear end
I don't know, 500/500-ish... Is there a prize for the closest estimate? If so, I will refine my answer to 515/525 @ the wheels.
Regardless of the numbers it produces, that is an idiot simple combination, and I bet it has good, useable power everywhere. You can always port the heads and blower, change pulleys and cam, **** like that is easy enough to do down the road.
Did you ever get this on the dyno?
I'm doing an almost identical build. LY6/LS9 Cam/LSA Blower/4L80e/ Stainless Works long tubes going into a 2000 S10 Xtreme. I've been thinking I should make right at 500hp to the wheels. I could have easily pullied up and ported heads/blower and more cam/stall and been well over 600hp but I want this to drive like a stock vehicle.
My other project is my weekend get out of the F-N way build. 1951 Chevy 5-window truck with a 6-71 roots blown 408. AFR heads/FTI Cam/Morel Lifters/Callies crank and rods/Wiseco Pistons/Billet Mains/BDS Intake/ 16-65lb Holley injectors/Holley Dominator EFI. I bought the motor after it was hurt on the dyno, at 15lbs of boost It made over 900hp@ 5,300rpms then it wiped out the crankshaft. Previous owner decided he wanted more power so he decided not to fix it and went to a BBC. Hope to get started on that build this summer.
