What and How do you think it will run?
hey guys!
hey everyone, I'm new here and was wondering what the experts think of my setup I am working on. I have a 2005 Avalanche 5.3 flex 2wd.
I have replaced the rear with a GM performance rear with 3.42 posi.
the tranny is a stage III racing 4l60e with corvette servo and solenoids, and all hardened internals and racing parts, with a 1800-2000 stall convertor.
the 5.3 is bone stock crank, pistons, rings, with 156,000 miles.
The heads are factory 706 heads, that have been ported and polished, with factory valves, but will have the 2014 6.2 supercharged ls9 beehive valve springs with the cam and lifters, pushrods. new oil pump, timing chain and gears, head gaskets. I have had the 6.0 truck intake ported and polished and replaced the factory throttle body with a jet performance 98mm throttle body. I am also adding twin T4 turbo with 8-10 psi boost, running through an intercooler.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I plan to keep my truck as a daily driver but as a play toy occasionally. any ideas or suggestions? Thanks in advance
