Bigger Headers/ORY Setup Gains? (Boost the same)
So I upgraded my exhaust this winter and re-pullied the blower back to ~8-9psi. The car previously made 598whp/554wtq on 8.5lbs (16* of timing w/ 11.2 AFR @WOT) with the old exhaust setup. How much do you think I will gain with the larger exhaust given all other things the same? (boost/timing/etc)
Old: 1-3/4 BBK LT's with 2.5" catted Y, cutout (open) and base SS muffler
New: 1-7/8 Speed Eng. LT's with 3" ORY, dynomax 3" intermediate/over axel pipe and Factory SLP CME muffler.
Rest of the setup:
SBE LS1
D1sc (8-9psi) w/ FMIC setup
Ported 243 Heads
PAC 1218 springs
TSP 228R 112
FAST 102 intake/ NW 92 TB
60# injectors / Holley EFI hi-flow rails
FLT 4l65e w/ Yank SS3600
Stock 10 bolt (3.23 gears)
Rest of the setup:
SBE LS1
Ported 243 Heads
PAC 1218 springs
TSP 228R 112
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
So no cutout with the new setup correct? Even if so, you should pick up a good bit from the y-pipe change for sure. As to how much, that's really hard to say. Depends on how much the current setup is restricting it
Also, the car is SD tune on 93 and water/meth.
