6.0 w/ 88mm Turbo HP? Terminator X and Injectors
So, I'll be ordering my Terminator X and injectors real soon. And this is my first performance LS project. Wanting to see if anyone has any insight on what potentially my HP level might get me? (Please keep in mind, we'll have to tune through the boost to see how much we can stab at it) Feel free to suggest an injector size/brand, as I need to buy the proper Terminator X to match the injectors.
Gen 3 6.0 Iron block
Gen 4 Rods/ Flat top pistons (new rings/bearings)
Comp Cams 54-459-11 (231/239@.050 .617.624 Lift 113 Lobe Sep)
TBSS Intake PTK 92mm Throttle Body
317 Heads with BTR platinum spring kit (casting smoothed, wouldn't call it ported)
VSR 88/102 T6 1.32AR Single Turbo
E85 only
Terminator X EFI
All of the injector charts are based on HP levels. I've watched alot of videos and read around on similar combos. I was thinking 1000hp (flywheel) should be fairly attainable.
Any thoughts?
E85 only
Terminator X EFI
Any thoughts?
E85 only
Terminator X EFI
Any thoughts?
E85 only
Terminator X EFI
Any thoughts?
The following users liked this post:
cturboaddict (04-07-2021)
i have pretty much the same combo. Gen 4 5.3 stock bottom end, gapped rings, ljms stage 3 cam some johnson lifters, btr plat springs, term x, vsr 88mm, e85 and a 5 gal aeromotive pump kit from motion so i think the goal is very doable. Alot of people pushing over 1000hp to the tire
