Can anyone give me a idea on the hp at the wheels
99 true SS
6 speed
New Built ls6 (04 zo6 block)
Katech rods and rod bolts
Line honed and fully balanced
.5 over flat top pistons
Ls7 lifters
Comp cam 232/239. .598 /.612 114+4 lsa
Trickflow heads /top end kit from Vengence Racing (not the as cast series)
.660dual springs titanium retainers and clips
Chromoly pushrods
Fitech sheetmetal intake w fuel rails
102mm tb
Chris1313 ram air kit
Slp lid
411 pcm
New stage 3 spec clutch
Tick performance adjustable master/slave cylinder
New alternator
2.5" drop spings all around
BMR adjustable panhard bar
BMR torque arm
BMR crossmember
BMR relocation brackets
Offset Double adjustable rear control arms
Stock 10 bolt w new 4.10 gears with Auburn carrier
Jegs spiked ssr drag pack 17x4.5" in front 15x10 rear w nitto drag radials 325/50s
Powersteering delete
Ac delete ( still have everything minus compressor)
Long tubes into 3" y pipe with electric cutout
6 speed
Ls7 lifters
Chromoly pushrods
102mm tb
Slp lid
411 pcm
New alternator
BMR torque arm
BMR crossmember
The following users liked this post:
G Atsma (05-06-2021)
