Can I Run 12's ?
I have a 2002 WS6 with a spec stage 2 clutch, chromoly flywheel, lca's, sfc's, adj phb, p&p tb, lid and k&n, Hooker coated long tubes, running through exhaust cutouts. I have not been tuned and I will be running on street tires. Looking for thoughts and opinions, I appreciate all feedback.
I went 12.6 in an A4 99 WS6, mods were pretty much the same minus the cut outs. Plus you have the ls6 intake which I did not at that time. Also I was on nitto drag radials which I hated, so like he said if you hook your there.
My friend had a completly stock 02 WS6 M6 with street tires and it would run low 13s when it hooked. Theres only 1 way to find out
good luck hookin.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
