700HP NA LT1 Built For Lots Of Nitrous
Well first off i really hate to sell this but im trying to buy a house so im just seeing if there is any interest... i built this with the intention of being the fastest nitrous lt1 in the world...not one single penny was spared in building this prodject and it was built with some of the most knowledgable people in the world behind me.... i built this engine while attending the School of Automotive Machinist (www.samracing.com) and with them behind me you know everything has to be 100% correct....i have almost 19k invested in this motor in PARTS alone and being the machine work was free if you had to have this motor built you would prob have another 5k in machine work in it....
well ill start to break down the price list and parts break down as best as i can:
Block: $500 96 lt1 block with 45k miles originally, half filled with moroso block filler
Crank: $1200 Callies Dragon Slayer 3.875 Stroke, Internally balanced front and back
Rods: $800 Oliver 5.850 with ARP 2000 Bolts
Bearings: $225 Clevite H Series Chamfered and oil Grooved
Pistons: $1450 Custom JE's with every option, Side Pin Oilers, Lateral Gas Ports made to handle 400+ of nitrous
Main Caps: $200 Pro-gram Splayed Billet
Piston Rings: $250 Hell Fire 3/16 3/16 3mm
Lifters: $450 Isky .180 offset W/ Guide bar, Solid Roller
Cam: $350 Comp Cams Solid Roller 268/284@.050 114LSA(installed at 112) .440 lobe lift
Oil Pump: $125 Canton High Volume Pump W/ Canton Pick up
Timing Chain: $150 Cloyes Hex-Adjust Double Roller
Head Gaskets: $165Custom Cometic 4.060 bore .050 thick (.040 quench)
Cylinder Heads: $4500 plus $350 to clean up AFR 215 Raised Runner CNC'd Then Cleaned up by Brandon (Cylinder Head Teacher at school)
.200 .300 .400 .500 .600 .700
143 209 263 306 331 338
Valve Springs: AFR(REV) 320 Seat Pressure 720 Open Pressure, good for .750 lift
Fasteners: $ 500 ARP Studs Throughout, Main,Head,rod bolts, intake bolts,valve cover studs, Everything
Rockers: $1200 Jessel Pro Series 1:7 ratio
Pushrods: $375 Smith Brothers 3/8
Intake: $400 Dart-42521000 $800 Ported by Brandon and i must say this intake looks AMAZING, it matches the heads perfect
Carburetor: $1450 Braswell Dominator Built Specifically for this engine
Balancer: $400 Fluidampner
Valve Covers: $225 GM Performance Parts Cast Aluminum, Powder Coated Black
Oil Pan: $250 Canton 7 Qt
Crank Trigger: $275 MSD Flying Magnet Crank Trigger
Water Pump: $150 CSR Electric Pump
Vacuum Pump: $560 Moroso-22642 4-vane
Catch Can: $75 Moroso Vacuum Pump Catch Can
Motor Plates: $ 350 Mad-man Front and Mid Plates
Oil Gallies: Main Oil Gallies Drilled out and Restrictors installed
Distributor: $250 MSD Pro Billet Low Profile Cap
Plug Wires: $150 Moroso Race Wires
that right there is $18,125 in Parts alone.... im sure there is quite a few more little things that i forgot.
The only Time that is on this motor was on the Engine dyno at school. it had 5 gallons of 110 octane ran through it and it made 680hp at 7,300 rpm and and 522.8 ftlbs tq at 6,400 rpm...this was with out my carb on it and with no vacuum pump... i feel it should make 720ish once broken in fully and tuned some more with my carb and vac. pump on it.
im looking for about 15k Serious inquiries only
For Serious Buyers only Please PM me or Email me at Fran@RaceProvenMotorsports.net
or give me a call at the shop 302-798-4000
Fran
Race Proven Motorsports
302-798-4000
Fran
302-798-4000
