Fbody - Moser 9" rearend (full options with backing plates)
Moser 9" - full options with backing plates
Moser 9 Inch rearend narrowed 2" per side
F-body application 98-02
rear will actually even work for the 3rd gens
because it's narrowed 2" per side which is 3rd gen spec.
what all it comes with:
Eaton detroit locker
Torque arm mount
31 Spline Axles
Aluminum Moser thru bolt center
Drain plug
Extra fill plug
Black paint finish
Anti-roll bar brackets supplied and welded
ABS/TCS 4 channel option
Exciter rings supplied for 4 channel
GM LS1 4 channel backing plates
optional tapered axle bearings pressed on
Since the backing plates are already pressed on and supplied
this is basically a full boat optioned Moser 9" that's ready to go
3rd member is BRAND NEW
3.70 gear ratio
Moser aluminum thru bolt case
aluminum pinion support
1350 billet yoke
No expense was spared in building this rear.
Cost to replicate with all included options and supplied GM parts
would be 4K+
Housing and axles have aprox less than 100 miles
distance from shop to my garage.
Price is 2999 prefer
pick up in the NJ, NY, PA
Torque arm mount
31 Spline Axles
Drain plug
Extra fill plug
Black paint finish
3.70 gear ratio
1350 billet yoke
would be 4K+
