Freshened up 366 turbo race shortblock...built for SERIOUS boost
I'm selling my old 366 shortblock setup completely freshened up...
good to 1500hp with LS2 and 1500+hp with iron block
Motor is still apart, will be built with your option of block
Option 1: blueprinted 6.0L iron block @ 4.010 bore
3.622 callies magnum XL crankshaft
6.125" GRP Pro1200 aluminum rods (the super severe duty rods)
Rods were just checked by GRP and they are good to go
JE -22CC inverted dome pistons (~8.8:1 compression with 60cc heads) coated sides and top
new ARP main studs
fresh rings and bearings
pinned OEM main caps
hardblock in the waterports for added rigidity
Va Speed solid roller turbo cam (will give specs to buyer)
ATI flexplate setup
80 runs on the crank and pistons
35 runs on the rods
$5000
Option 2: same as option 1 except for a new LS2 block
$5500
Motor will be assembled by Shawn @ Va Speed
shawn can do the double oring machining to block and your heads for extra fee
can work out deal if you provide a core block.
Also will sell the matching ATI torque converter if interested
new ARP main studs
ATI flexplate setup
35 runs on the rods
$5000
$5500
new ARP main studs
ATI flexplate setup
35 runs on the rods
$5000
$5500
new ARP main studs
ATI flexplate setup
35 runs on the rods
$5000
$5500
Are you sponsoring? I have a certain silver 98-99' Camaro that you know of.. It would make a good car for the Fireball Race team...LOL
