Elemental Designs Nine.1- 1,000w mono amp
Up for sale is my Elemental Designs Nine.1- 1,000w mono amplifier. I had it in my T/A when I was running a 10" sub. The system has since been removed.
Here are the amplifier specifications:
1200W x 1 @ 1 Ohm
900W x 1 @ 2 Ohm
450W x 1 @ 4 Ohm
Height : 2.250"
Width : 9.850"
Length : 15.875"
Overall Length(w/ feet) : 17.175"
Detailed Amplifier Specifications:
Signal to Noise Ratio: >95dBA
Variable Input Sensitivity:150mV - 7.0V
Remote Variable Input Sensitivity:No
Variable Low Pass X-Over: 50-250Hz @ 24dB/octave
Variable High Pass X-Over:None
Current & Thermal Protection:Yes
Remote Gain Control:Yes
Variable Phase Control:Yes
Master / Slave Option:Yes
Efficiency:64%
Variable SubSonic Filter:10-55Hz @ 24dB/octave
Fuse(s):4 x 30A
Max Current Draw:130 Amps
Damping Factor: 300
It retails for $350.00 new. I will let it go for $200 OBO + shipping. It is in great condition and worked flawlessly when I used it. Here is a picture of it:
Thanks,
Andy
1200W x 1 @ 1 Ohm
900W x 1 @ 2 Ohm
450W x 1 @ 4 Ohm
Height : 2.250"
Width : 9.850"
Length : 15.875"
Efficiency:64%
Fuse(s):4 x 30A
Damping Factor: 300
Thanks,
Andy
