Ls3 short block,heads,intake
OK LS3 MOTOR WITH ONLY 1900 MILES ON IT!!! HAD A CAM PROBLEM BUT JUST NEEDS 3 INTAKE VALVES ON RIGHT HEAD AND GOOD TO GO
LS3 6.2 SHORT BLOCK -----$2000 (BLOCK ALONE IS $1600 NEW)
LS3 HEADS THAT ONE HEAD NEEDS 3 VALVES AND HAS PATROIT GOLD DUAL VALVE SPRINGS ------$600
LS3 INTAKE WITH INJECTORS, RAIL, GASKETS AND INJECTOR HARNESS FOR LS1
$350
Lingenfelter TRG-002 58x To 24x Crank Sensor Trigger or Reluctor Wheel Conversion Module DOES CRANK SIGNAL ONLY------$150
NICKWILLIAMS 92MM THROTTLE BODY ----$300
THANKS AJ 717-654-4397
$350
