TR 224 Cam with Ported 853 heads
UNDER PRESSURE MOD
Yup, this is my old setup which was quite impressive. The heads were hand ported and flowed by Joe Prince, one his last sets that he did before having troubles. I never cc'd the runners, but I know the heads were milled 0.030" to bump compression a little. The valves were all lapped in by hand and there was an easy 40 hours into these heads as every single runner, exhaust and intake was flowed and matched.
When I dyno'd, I had an ls6 intake on the car, stock throttle body and maf, macs with a crushed ypipe, see image below, and a box tune that was far less than ideal. On an optimized setup with a better intake track (maybe a fast or ported throttle body/maf) and a better exhaust, this would certainly put up numbers that would have people scratching their heads with why they went with monster cams.
I dyno'd this summer on a dyno dynamics load bearing dyno, which I'm not 100% confident in, but it put down 468/460, which on a dynojet I'd guess would be around 440/425. Not bad considering the amount of low end torque I had. The only reason I sold this setup is I'm planning to go with more cubes in the future, and I bought a set of PI heads that will grow with my cubes in the future.
Here's the dyno from the week before I took off these heads...
Whatever the actual numbers are, look at the torque curve.... It's not a peaky setup that you need 4.56 gears or a 4000 stall converter to enjoy.
Hell, if it helps, I'll send my tune file to who ever buys this combo. It might not be perfect because I had a Fast 90/90 combo but it'll get you damn close.
