PST 3-1/2 Inch Aluminum Driveshaft w/Forged Yolk
Just did a 4L80E swap so got a new driveshaft, heres the info on the driveshaft as per the manufacturer. the driveshaft is at East Coast Supercharging in New jersey if you would like to pick it up. 4L60E/T-56 to 9-Inch Length. $350 SHIPPED.
-PST DRA3.5 Drag Racing 3-1/2" 120 Wall Aluminum Shaft with forged Slip Yoke.
9-Inch 45-1/4" seal to center. PG1350 1350 Upgraded Slip Yoke Forged PG
-3.5″ X .120″ 6061-T6 DOM Aluminum Shaft
Street - Strip Aluminum Driveshafts. 1000 HP Rating! 5 to 6 lbs lighter than the PST Chromoly Driveshaft.
-Product Description:
3.5″ Shaft with, 1350 Series “Gold” Cryo treated Solid U-joints, are built under the most Stringent Tolerances in the industry. Tubing is Factory Straightened to .010″ total runout at the center of the tube. Tube yokes are welded to within .006″ runout on each end. The shafts are Electronically Computer Balanced to less than 1/8 Oz/Inch, as an assembly, assuring smooth operation at the Big end as well out of the hole.
-We recommend the 3.5″ shaft in most cases to 1000 Horse Power. 4″ Shafts are recommended to 2000 Horse Power. The shafts are given a brushed finish.
