Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
My turbo build
Old Nov 2, 2008 | 05:25 PM
RealQuick's Avatar
Default My turbo build
My turbo LT1 Build:
Engine
Golen Engine Services 383ci
Eagle Forged 4340 3.75' crank
HRC 5.7" rods
JE -31cc Pistons
4 bolt main conversion w/billet caps
ARP rod bolts, main studs, head bolts
new LT1 oil pump w/white Z28 hi-pressure spring
GMPP single roller timing chain
keyed crankshaft hub
CC 218/230 .528/.510 114LSA w/crane Gold 1.6I/1.5E rockers
Bone stock LT1 heads/intake
BBK 52mm Throttle Body
Power Adder
LT1 Boost Cast Manifold Budget Kit
Stock LT1 Cast Manifolds, 2.5" crossover pipe, 3" DP
Precision T76 GTS .96 A/r
JGS 40mm Wastegate
JGS 56mm BOV
31x12x4 Air to Air intercooler
Coolingmist Alcohol Injection Kit
Turbowerks Oil Scavenge Pump
Ignition
Taylor Spark Plug Wires
NGK TR6's gapped at .033
Stock Opti
Stock Coil
Fuel System
Single Walbro intank 255 with Racetronix Hotwire kit
Stock lines, regulator, rails
60# Mototron Injectors
Cooling system
Meziere Electric Water pump
160 Degree thermostat
Stock Radiator
Be Cool Duall 11" Electric Fans
throttle body coolant bypass
Drivetrain
Stock 6 Speed Transmission
B+M Ripper short-throw shifter
Mcleod Street twin clutch/flywheel
1LE aluminum driveshaft
stock Gm 10 Bolt rearend 3.42 gears
Suspension
HPM subframe connectors
BMR shock tower brace
BMR tunnel brace/driveshaft safety loop
Tuning
Stcok OBD2 PCM
LT4 Knock Module
Pics:
Old Nov 2, 2008 | 05:26 PM
RealQuick's Avatar
wow those pics came out big!
Old Nov 2, 2008 | 05:57 PM
Slowhawk's Avatar
LS1Tech Sponsor
Looks good.I'm surprised you welded onto the cast manifolds.I've been told to never do that because the weld would be very weak.
Old Nov 2, 2008 | 06:03 PM
RealQuick's Avatar
Thanks. Hopefully it lasts. I have a beefy support bracket holding up the turbo.
Old Nov 2, 2008 | 06:18 PM
subarubill96's Avatar
you are so taking me for a drive when i come to get my wheel
Old Nov 2, 2008 | 06:34 PM
My84Z's Avatar
Great work bud! Glad to see that ta in action again! Also glad you got some ***** back and can work on your own car without being in the doghouse!
So where's my kit?
Old Nov 2, 2008 | 06:46 PM
RealQuick's Avatar
Bill - If the weather is OK, I'll take ya for a spin.
John - this is the first time the T/A has been apart. you are thinking of my beloved, and long gone white Z28 (: if ya have an LT1, i'll make ya a kit, but no interest in ls1's at this point.
Old Nov 2, 2008 | 06:49 PM
My84Z's Avatar
No I remember the t/a when JGeorger had it but i meant working on any car before
Old Nov 2, 2008 | 07:23 PM
RealQuick's Avatar
i always do my own work, just didnt get the Z back up and running How is married life treating you?
Old Nov 2, 2008 | 07:26 PM
My84Z's Avatar
I meant someone wouldn't let you work on your car geesh lol Married life I wouldn't know I got the house but unfortunately the fiance got sick and needed some surgeries and stuff so we postponed the wedding twice so far but with alittle bit of luck she should be fine soon and then we can get back to life.
Old Nov 2, 2008 | 07:57 PM
RealQuick's Avatar
Yikes! Hopefully she is doing better!
Old Nov 2, 2008 | 08:17 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'd just like to see John drive one of his cars down the road
Old Nov 2, 2008 | 08:25 PM
RealQuick's Avatar
Thats cold blooded Don!
Old Nov 2, 2008 | 10:34 PM
My84Z's Avatar
he's too busy taking them apart and forgetting to put them back together lol
Old Nov 3, 2008 | 12:16 PM
CamaroRacing12's Avatar
hell of a shop car
Old Nov 3, 2008 | 12:37 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Looks good Jon, I know you will get this pig running!
Old Nov 3, 2008 | 05:45 PM
ForcedInduction's Avatar
holy resize!
Old Nov 3, 2008 | 07:25 PM
RealQuick's Avatar
I know! Sorry guys i linked them from my homepage where the pics are like 1/3 the size.
Old Nov 3, 2008 | 08:26 PM
My84Z's Avatar
so is it running yet?
Old Nov 3, 2008 | 08:48 PM
RealQuick's Avatar
Not yet Started making the cold side piping. didnt make much progress tonight after work.
