Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Will I have problems...
Old Oct 2, 2009 | 09:08 PM
JonasSS's Avatar
Default Will I have problems...
Looking to take my 2001 Camaro SS and replace the stock headers, cats and Y pipe with http://www.texas-speed.com/shop/item...id=181&catid=8
or similar...
Exhaust will be the Hooker 16811HKR Muffler
NOW-
I have a PA license .. I travel through NJ and work in NY. Come emissions time in PA, can I get away with this setup or will they flag the hell outta me?
Wanna see what i got in my exhaust?
Old Oct 2, 2009 | 09:29 PM
Tom01ss's Avatar
no im an emissions inspector, this will work perfect , reasone being b/c it has cats which is a big fed thing, theres like a 10k fine for not having cats or moding them and getting cought, its spelled out in the anti tempering and visual inspectio section.
Old Oct 2, 2009 | 09:48 PM
JonasSS's Avatar
Ok .. slightly confused .. I can't rad that straight. A catted Y pipe will or wont pass insection here in PA?
Old Oct 2, 2009 | 10:22 PM
JonasSS's Avatar
*bump*
Old Oct 2, 2009 | 10:30 PM
DiabloFormula's Avatar
It will pass.
Old Oct 2, 2009 | 11:40 PM
mrhzk35404's Avatar
Well, if you want to get techincal it won't pass. I believe the law reads that you can't move the location of the cats at all from the factory location. Correct me if I am wrong.
Old Oct 2, 2009 | 11:52 PM
SheaMus's Avatar
Matters by the garage where you get it inspected. I had no problems with my car and i have not cats. The places i went to just looked to see if there was a SES code showing on the OB computer. When you instal Yourafter market exhaust make sure you buy 02 Sims or get the Codes deleted for the rear 02 Sensors
Old Oct 3, 2009 | 12:15 PM
JonasSS's Avatar
By o2 sims your speaking about the resistance jumpers that fool the computer by making it seem like sensors are there and everything is green right?
I heard about those
Old Oct 3, 2009 | 12:35 PM
Devilish34's Avatar
What model years do they read through the port and not the tail pipe? After 04 or???
Should pass though
Old Oct 3, 2009 | 12:44 PM
highflyin's Avatar
Should pass though
OBDII which is 96 and up. 95 and under is read out the back.
Old Oct 3, 2009 | 02:03 PM
JonasSS's Avatar
Well, now this is the problem I'm running into. I need to make sure i have everything so I dont run into issues come time to doing this work. I want to have everything I need .. no more .. no less .. it's just how I work ..
Old Oct 3, 2009 | 09:36 PM
JonasSS's Avatar
So for all of you PA'ers, if you have a similar set up .. either an ORY or Catted Y (non stock) ... I'd be all ears for inspection stations you have used and gotten by with.
Old Oct 3, 2009 | 11:32 PM
What part of PA are you getting inspected/emissioned in? I have multiple "friends" that will pass you.
Old Oct 4, 2009 | 01:30 AM
V8 FC's Avatar
some parts in pa you don't even have emissions, in the poconos where i live we have no emissions here its great!
Old Oct 4, 2009 | 09:58 AM
JonasSS's Avatar
I'm right in Kunkletown, Brodheadsville area. Close to 534 + 209
Old Oct 5, 2009 | 08:18 AM
V8 FC's Avatar
ok so you are by jonas area, i didn't think they had emmissons there. come move over to east stroudsburg you will be good here we have no emmissions check here, if you want i can contact my buddy who lives over there, he has a turboed integra, he has never complained about not passing anything
Old Oct 5, 2009 | 09:30 AM
JonasSS's Avatar
Yeah .. so far .. I'm looking at a full hooker exhaust set up .. LT headers, ORY and catback (odd considering I wont have any to call it that).
What I need to do is figure out if its better to Jump the o2 sensors or get the computer re-write.... I just dont know where to get the codes or .. who to go to in order for the codesto get re-written
Old Oct 5, 2009 | 10:31 AM
massls1guy's Avatar
If you plan on keeping your car you may want to go with a stainless setup. Costs more but it will last longer.
Old Oct 5, 2009 | 10:40 AM
JonasSS's Avatar
Well, going with ceramics for the extra heat draw off - and as far as lasting, I'll be within a year throwing a turbo in. So the headers will hit craiglist with plenty of life left in them anyway ...
Still: What I need to do is figure out if its better to Jump the o2 sensors or get the computer re-write.... I just dont know where to get the codes or .. who to go to in order for the codesto get re-written
Old Oct 5, 2009 | 12:33 PM
massls1guy's Avatar
You can probably find a tuner to disable your rear O2s. My rear O2s are disabled but I still have them on there with cats. A lot of people think the cats mellow the exhaust a bit, less raspy. Unless you're going for a mostly track oriented car I would keep cats if I was you.
Did you know TSP recently redesigned their cat'd Y pipe and it looks good, nice merge:
http://www.texas-speed.com/shop/item...d=189&catid=45
