Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Headlight motor issue
Old May 17, 2010 | 10:31 AM
ws6on19s's Avatar
Default Headlight motor issue
I'm having a problem with the driver headlight motor, it runs fine when the lights are turned on but continues to run for about 10 sec when i shut them off and when just the parking lights are on the headlights flip up but are not lit. the relay checks out ok, any suggestions thanks
Old May 17, 2010 | 10:38 AM
TNTramair's Avatar
check the connector plug. i had a similer concern on a buddies car and the connector was all corroded and ****. pulled it apart, cleaned the contacts and it was fine after that. just a suggestion.
BlackScreaminMachine's Avatar
Internet Mechanic
One thing I noticed as the car is running and driving. If I put on the head lights, they flip up. IF I want just running lights (parking), they will remain up. Otherwise they will close immediately.
Old May 17, 2010 | 10:46 AM
ws6on19s's Avatar
when i unplug the driver motor the passenger works fine, i can turn the fogs and parking lights on and the light wont flip up once i plug the driver side in they will both go up, i'll check all the connectors today.
Old May 17, 2010 | 11:21 AM
Krazy98Z28's Avatar
I believe you have to change the gear in the motor.
Old May 17, 2010 | 11:28 AM
Internet Mechanic
Yea, now that I think about it, maybe its worn a certain way where the teeth catch well one way, and has a delay on the other. Maybe a disection is in order.
Old May 17, 2010 | 11:33 AM
Krazy98Z28's Avatar
https://ls1tech.com/forums/pontiac-f...s-go-here.html
Old May 17, 2010 | 03:43 PM
ws6on19s's Avatar
thanks, thats the thread i was looking for, too bad i gave my spare headlight assembly to my brother wtf
Old May 17, 2010 | 08:16 PM
NXPRSS's Avatar
E-Rock, its Crazy Dave! what the hell you been up to!???
Old May 18, 2010 | 09:54 AM
whitdog54's Avatar
try doing the free fix (where u flip the gear 180*) if not just replace the motor.
Old May 18, 2010 | 01:07 PM
ws6on19s's Avatar
whats up dave, ive been restoring my house in woodbury since 08 thats why i havent been around or on here at all. how is the car running?
