cammed/nitrous tune dyno runs + graph inside 686whp :)
#48
Yep ya **** the bed last night. Guess you are done with racing... Atleast you saved some face last night and drove out after the big epic fail... LMAO!!!!!!!!!!!!!!!
#50
Haha, I might be interested if they are mounted.
Although my last run I hit my 11.1 again. I need some better practice. I did find out that I must have loaded the wrong tune on the car... was running about 7 degrees of timing less than I wanted to be, but the last run I only raised it up 3 because I couldn't remember if there was a reason I set it to lower timing or not haha.
I guess I should have logged my other runs. But on a positive note I found my car can do 0-60 in under 3 seconds LOL
Andrew
Andrew
#57
I didn't think the track was that bad. At least my last run I finally got my launch. Just so happens my clutch went the floor when I hit 4th gear. I fear it may be time to give up on the LS7...
11.1 again... god I want 10s.
