How to add SLP air box/ ram air?
Ok...this is going to be probably a SUPER stupid question....but im going to ask anyways lol.
I am looking to install the slp style intake and ram air on my 94 z28. I am installing a carb L92, and instead of running a traditional air filter (since there's no room in the cowl area anyways)....I want to run a 3.5-4" elbow off the carb air bonnet into an oem style box with a high flow lid and air filter.
Essentially I am looking to do the same thing as someone posted in my other thread but with a carb....
https://ls1tech.com/forums/carburete...x-4th-gen.html
My question is WHAT do i need to pick up? Is it basically a stock 98-02 air box with a high flow lid? Do the ram air setups work? Does anyone on here have the parts I would need to install this?
Thanks in advance. New to the lsx/ f-body cars.
Internet Mechanic
I would think a LS1 type radiator hold down (NON ram air) and then a SLP lid. IF you do not have a Ultra Z hood or something to take advantage of the front air gap, then get something to block the gap and allow the filter to grab from the bottom.
I have what is called a SLP flow pack and it works, nothing crazy but a sheet metal duct that draws air from the bottom. After you lift the filter off you see how the duct draws right infront of the A/C thingy.
FYI if you get a ram air one, the gap is bigger then the NON ram air and I am thinking with your hood, you do not need it, nor need to spend extra cash. Just get the NON ram air and get either a SLP duct or a Super Sucker (google it)
you're only in wallingford huh?
I dont think thats too far from me (springfield ma).
So when you guys keep referring to the SLP lid, does that just sit on-top of an oem air box from 98-02?
Would something like this scoop work with the stock box and slp lid?
