CT Emissions Question
I guess try to be cheaper but don't wait as you only get so long on temp tags and if you run out you gotta tow the car there.
Will I fail emissions for a air conditioning code?
Also, I was going to do emissions today and saw the ac code so I deleted it. Now I have to go through the driving cycle. How long is this going to take?
I have rear o2s tuned out and air tuned out. No egr its a 01.
Thanks.
Thanks.
I would think your fine as the code is not engine/emissions related. Since you shut it off I see no reasons to worry. IF you cleared the PCM I would put enough cycles on it to just in case.
Now I need for someone to tune out the ac code?!
