Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
CT Emissions Question
Old Aug 5, 2011 | 02:51 PM
JaxJags's Avatar
Default CT Emissions Question
Hey everyone. Just bought a 94 Camaro Z28 from a guy in NY. He cut off the muffler, so I bought a muffler from Summit and installed it myself. Will I be ok for emissions now? It's a 94 so it has OBDI, so I don't think they're going to check for codes, they'll just run a sniffer right? Also, will they have a safety inspection since it's from out of state?
Thanks
Old Aug 6, 2011 | 09:56 AM
djjonesivs's Avatar
sounds about right.
Old Aug 6, 2011 | 11:19 AM
thechef's Avatar
Moderator
you will just need to go to emmissions for the sniffer test, that is all...
just make sure there are cats on the car.
Old Aug 6, 2011 | 12:54 PM
JaxJags's Avatar
The factory cats are still there. In the short future I plan on getting pacesetter lt's, a catted y, and a catback; will that pass emissions?
Thanks for your answers.
Old Aug 6, 2011 | 12:56 PM
mac62989's Avatar
Ya that should be fine
Old Aug 15, 2011 | 06:45 PM
JaxJags's Avatar
So I got it tested, and it failed today. I don't know why. I have stock manifolds, both catalytic converters, and a muffler on the car. I think the previous owner messed with the computer.
Here were my results:
Old Aug 15, 2011 | 07:03 PM
Formula413's Avatar
Is your check engine light on? How does it run? Seems like with those numbers you would notice something.
Old Aug 15, 2011 | 07:22 PM
JaxJags's Avatar
The light is on. I haven't ran it for any codes yet though. I think it runs fine.
Old Aug 15, 2011 | 07:25 PM
Formula413's Avatar
Yeah get that scanned, you might have bad cats, a misfire, bad O2 sensors, or any/all of the above.
Old Aug 15, 2011 | 09:22 PM
JaxJags's Avatar
Yeah, I think it may be the cat. After 17 years and 155k miles, I think the stock cat had enough. I'll try and get it scanned. Thanks for your help.
Old Aug 16, 2011 | 06:26 AM
BlackScreaminMachine's Avatar
Internet Mechanic
What I can tell you is most likely those CATs are blown out. Once you have it apart, take a pic and lets see how they look.
What I would start with is a basic tune up which is plugs, wires, fuel system cleaner, and other things a 150k+ vehicle needs. This is just good business.
Then since you need to pass the sniffer, have '93 octane in the car and a few bottles of rubbing alcohol, it will help clear out the tank and clean out the combustion chambers, injectors, and keep those plugs clean. Also run the hell out of the car to get it nice and HOT since cats work best that way and get to the shop earliest to get in first. Hotter the better.
Muffler does nothing to scrub out emissions and if you have lights you may have other issues. Kinda wished you had posted this BEFORE going as we can help you but once you fail, you HAVE TO FIX IT.
The issue I see is you had not mentioned if the car had been modified and if it has, with what!? PCM certainly could have been messed with and a clean reflash would be optimal but if it does have stuff done to it, it may not run right still. I would think a little more info would be benefical to you and your issue.
Old Aug 16, 2011 | 08:59 AM
JaxJags's Avatar
To be honest I don't know a whole lot about the car. I bought it a couple weeks ago. All the car has is a cold air intake. Everything else is stock. I looked at the plugs yesterday, and they look good, yet I don't think they've ever been changed.
Old Aug 16, 2011 | 09:24 AM
Internet Mechanic
At 150k, you need to change them. Just start going through it now. Get a Scanner and scan all the DTC codes it kicks so we can help you.
Old Aug 16, 2011 | 10:48 AM
mac62989's Avatar
You realize you automatically fail with a Check engine light on.
Old Aug 16, 2011 | 10:58 AM
JaxJags's Avatar
I took the bulb out.
Old Aug 16, 2011 | 11:05 AM
Internet Mechanic
Not on ODBI cars. You need to pass on the roller. 1996+ ODBII cars are scannable emissions.
Old Aug 16, 2011 | 06:14 PM
djjonesivs's Avatar
You failed because they sniffed the vehicle , all of your exhaust gases were above the limit.
You could try changing the cat, but it could be other things.
Old Aug 16, 2011 | 10:28 PM
JaxJags's Avatar
So far I think it's the cat. I'll try and look at it tomorrow. I'm going to change the plugs and wires, run some seafoam in the fuel tank to clean the injectors, run mopar combustion chamber cleaner to get rid of the excess carbon buildup, and replace the cat. I should also go over the EGR valve and O2 sensors correct?
Thanks for all your help guys.
Old Aug 17, 2011 | 06:24 AM
Internet Mechanic
A brand new cat, nice and hot, running some rubbing alcohol will most likely do the trick.
Old Aug 17, 2011 | 09:29 AM
thechef's Avatar
Moderator
i would start with the simple things first, tune up, seafoam, mopar top end cleaner and then go retest..
also get that code checked so you know what that is about
i believe its free to retest a failed car so i would go back and retest before spending money on a cat...thats my opinion
