Need a DTC Turned Off
P0452B Fuel Tank Pressure Sensor Low Voltage
I have emissions thats past due and I have to get this done. Any help is appreciated. PM me.
Located in Connecticut and for this car I do not have have tuning software or cable so its gotta be in person. The code needs to be turned off and that was the only one kicking.
Not looking to drop the tank and most of the Diag info there requires a Tech II which I don't have so. Any direction is appeciated. I may have one lead but if you know anyone with access to software would be great.
Thanks!
-Aaron
What I actually refering to is to remove the DTC from the PCM so it wont come back, ever.
I have something thats either a connection or a failed sensor but you need a TECH II to track it down and I am not spending 90+ Dollars per hour for Diagnosis from a Stealership. Autozone and Dealerships do not have the software needed eliminate this code.
Slowhawk was very kind in helping me out so at this point I am all set, thanks for the replies.
also take a ride up to slowhawk and have him delete the code right there make a nice road day trip out of it
